Can't get the headlights open!
Dexter
Houma, LA
Well today I decided to start working on my latest project: Retrofitting Acura TSX projectors into my stock Expy headlights. I read a few guides on how to do it and the project is well in my comfort zone. I popped one of my headlights in the oven at 225F for 15 minutes and then tried to pull them apart. I held the clips up and tried pulling the lense off...It didn't budge at all. From what I read it shouldn't be this hard and I didn't want to break/melt anything by sticking them back in. Is there some trick to these?
panda24619
San Diego
let it sit longer. try 20 mins then 25 then 30 and so on. there is a fine print that says, time varies with lights. so give it a try with a longer time.
Dexter
Dexter
Houma, LA
Some guides say 200F some say 250F. What temp should I be comfortable baking these things at?
sgtowing
Supporting Members
Valrico, Fl
Not trying to be a smartass but be careful.
Sent from my DROID BIONIC using Tapatalk
ELVATO
Orlando, FL
I don't remember what temp I set mine at, but it took 10-15 mins in the oven. Once you can get a little bit started, pull and they come undone in less than a minute. If you have to, work a little at a time pulling a bit, then sticking them back in for 2-3 mins, then try again.
I had a spare set so I didn't care too much when tried it. I put them in the rack, so one of them started to warp in the corner. I'd recommend getting a least one spare headlight in case you mess up. Especially with your Limited lights. The way I see if, get a cheap pair, and open those up. If you succeed, paint them black and keep the stockers untouched.
Also, I was doing this with an oven glove on. They will be hot when you first pull them out. If you can comfortably touch them, they're not hot enough. I think the temp was either 215 or 250.
EDIT: Nevermind, I guess my memory isn't what it used to be :p It was 200 degrees for 12 mins.
http://www.f150online.com/forums/ap...w-take-03-06-expedition-headlights-apart.html
Dexter
Dexter
Houma, LA
VERY helpful. Thanks. I was considering putting them on a piece of damp wood in the oven to prevent them from melting.
ZombieSoldier
Ludowici, Georgia
I always do 215 for about 10-15 minutes. Make sure it's face down on a terry cloth towel.... Nothing worse than seeing the lens start to melt inward!
2000eb
just me i wouldnt put wood in the oven even if it was wet...
