Cargo Net Recommendations
Malux
Orlando
First shopping trip with the expy went well save for the milk that dropped out of the trunk when we opened the lift gate and spilled all over the driveway.
Would love to get a cargo net. Any recommendations?
Langer
Chicago
No recommendations on nets, but I open the glass so I don’t lose any items out the back. Keep us posted if you find anything.
mjp2
Howell, NJ
I've got one of these:
https://www.amazon.com/dp/B075B6RVYW/
In addition to the adhesive backing I drilled the supplied screws into the interior plastic trim to secure the mounting points and have had no issues with anything coming loose.
Most of the time the bottom stays attached and I keep the top detached and stowed under a weathertech cargo liner. It's been handy and is certainly cheap enough.
M
Malux
Orlando
hmm, that's a good idea, but that would work for me, but not my wife and kids unloading the groceries solo, i think...
she could probably reach in there and move things around before opening the gate, but, she might not be tall enough to really see what she needs to move
99WhiteC5Coupe
I ordered and bought a new 2015 Ford Expedition Limited 4x4, and didn’t realize that Ford did not include a cargo net or provisions for one (or make it available as an accessory item) until after I bought the vehicle.
I have spilled cargo items numerous times out of the rear hatch, as items tend to shift rearward because the rear floor slopes down, toward the back.
This has to be one of the stupidest design features of the 3rd generation Expedition. My Expedition came standard with a stupid multi-color under-dash light feature which I have never used. I would trade the colored lights for a cargo net.
Just like with any vehicle, when you begin to drive and use them, you quickly find poorly designed (or missing) features. Mine seems to have a bunch of them too.
Anchorclanker
Statesville, NC
M
Malux
Orlando
awesome, i'll check this one out. Reviews look good!
M
Malux
Orlando
This really was piss poor planning on Fords part. I found this one on Amazon: https://www.amazon.com/MICTUNING-Th...Z6JE1Z06DVH&psc=1&refRID=6PTKT5K00Z6JE1Z06DVH (Wow that address was longer than I tought) I measured my 08 Limited. The rear width is 50.25" so this should fit with minimal stretching. It's on order and once it's installed I'll do my best to update this post.
awesome, would love to hear what you think.
I think they solved this problem with the 2018s, but I'm not 100% sure.
Jamo
Lee Center, NY
Mine has a floor panel at the rear that flips up to lock in the vertical or as an upper shelf. In my wife's Flex, she just uses a Tupperware bin to hold stuff in place. Everything moves when you have lots of space. If you want to see a sloped floor, check out the newer Suburbans...
creef14
VA
can you post pics of how your mounting points turned out?
mjp2
Howell, NJ
Geez....my truck is filthy! Don't notice when I see it every day but it really stands out in a photo. Anyway, yeah, nothing exciting there.
A few small holes and everything works great, though not everyone wants to drill into their trucks. For those that have no issue with it, the fire extinguisher mounted just above this shot has been a perfect, out-of-the-way location that's given me no issues with clearance or rattles.
mjp2
Howell, NJ
Yep. The panel comes off easy enough and with some big washers on the back side is sturdy enough for a small extinguisher.
Those scratches were there when I bought the truck. Poor thing lived a hard neglected life before I found it.
tommyddsr
Portsmouth, Va
Bought the same one recommended by mjp2. Mounted mine a little differently to get it tighter. I don't have the auto-lift tailgate so I had a few more options. Here are some pics of the mounting points. I cut an 1/8 off the bottom mounts so they sit flush. Fits great. I am going to install two more mounts at the bottom center to hold it down better. Will post those pics after it's done.
slUuJxbhm4lJddAe_Y8y6hTF7ECuZ8TJUYWMdBYpm9Jn4208fn12-gk9mC4j1OdJH_v3zKxywABOs0DVM5z8PVi7cqhfXw620TcLiQ14NOqjWSTEhs828RoND6ToJocPwsGu-c1_fVhAmGpdTUV7GXPLWQHxZKQvqrZejVjGtA2C3AD4_V0Ki7CdSddlF0KJyEZJYA7iE329OkVZlRwlR_kBof6ymLGkEgG9GbO3Q-w2sT-2o4ps7GjEHjXKbaL_td6d-Jh0y5JVTFw4PsFsMdAeV6Y6-UOfJpBSXzf59kmdsL-_k0M6CT3n8XPKB9Vl-LkWdtrJ1cTPFJSchgD64jhP8-Ntz0R4z2Sr5QR5Ict0bdyhRCe5or_c2WC8ZWg4qxGO6jdPAmMX6-0GQPtkuz827RHEZLOSc8RfmJEDHlpXnfU8L08MIY8vqoxhbCmKHTlE-plO5D3nhYsYy_z56gSe0luoWftmHe9X4G6gsRkO-J1zWdBmEoVSqOcN_fwSeqWantFJwsYhNmKLH-MozjWB37gu638pQTscAZ5cLeQRcgL8j-NIodWrGRcC8PxCo-eVBrbiWYsAHWRE-6816skuqy3ERKLMCrn4dg7-TWLwpjB2zkepmx3Hl1K_zS4vercWP7LFNrFNinaq_s7HuSZiY0wXawZt2Kz7YnWiZznawqC9MvaYDrA=w663-h884-no
zvrkKhdIKFUbz0VyWgIuL0M73SsjtEOhkTLT02fZ3s-_V-Ahdw9WZD_ZGB2oEKUqwUJzGIjZXqfyraqY1ULRdMHMecRIagofHSxPYZi44YpEPIznW6vS8qZmVkWSbpJjl0z-D7wvI-MRQp6Rl6roCJoGgynYN45l64IobnPMtPbUq0LAzLD0f43H9Sthx_7idI8I6_1ktMEqiAPUaDXQ3WYChWKex5dpYlcpQdfIH7y89_JQZ4RDegwsNrY3ZBbuOZaMDzr7SX_WM73XmKxr1Irsz4xpUsOm-DB6irqBzNeQQ3BwtuQ6N-hKbEP_56VBw9v3wbj6gnRjjMZ1v1dxKiqlOVZFo4ScZM1QEYbgpaSkFcWKjQZdIEvEVLdVUssyLZ_aeq021mHmJAQgEtJwhBaSZof8QIThylu8x71Et7s9ipYQaEQ5RW708QqXE_sfCFzdoydye1JFCpeE884_v8KLFj-v6dMM-h1AflD-0yV1fAW7bT270_wY8ng2wRP-mJL0bIY_6FtU06fv2D5WfQQ92I4DcW-7XNNp3dIcAb0yjLBBu38xXu47rF7nS1wH4X6g2b2lRDCT_JKwLdiugcIl4MoVrANSIIcHW-VikdX8IkDeJ1wx1Wk_Kzu81Q80pNCqalUB1EmEQqxs2ZbnU36qOT94MnI2HQQVykti5BHMFpokUV2creE=w663-h884-no
w07OsD4hju3h8A5e-hTNj07dBlkJrN66uNQ6LrNymQZagbSAEp58oafrWBVaoQD3Tahy-FENTwRv_A-cuKnpaNhyU_07mqPVaxNKznjXTwx8T8LL2bBmUwHjm5yMSK0CxfLvAsHIKrGKWsQVOFHGAT-KIf10GYN4OZ4FTGQooANMwOP6zHv5uId_CJgJOhToli3rt1QMtuEjNtPX2-5Xn3aJ_G79f-vtrZujqqO8zB2W4cqh17T6soErmyIF4Dd_MtDvAOTYP-sRLQMLnTN4LH2NycqxJnQDrcgFtJPwClZX0cULJwF8UxBQWIVCDHX1SkMUn4ZXy5GeH3Dq2BhJ7mUf0GOXZQLZ01J5DoB16msiUPNwJb97d2MCH3I5jfMMv0CvU0Y0zvsU93m8XMC_6z6-ykHlqe74z9uuB6qTY_WSXCdzpG7Gk0nVATknsyUirpk7ij72DtX3QmAzY2BXDaz9ZD3hBtZP70i4zqE2EapuzwxXln3atTFM7jT93wwqwXVB6Y-TxVE4SG493oI_0ciHw3lQU23Lb-cVCGjEvWz0n0ESWjvmvz2dtnIG8CY_g_2yI1IVV5nX6QpGGKYr3n6syf_bhhSpHR1CRtkSRYlTVf3vlQHHkH2heRDX-vTpwt7aPMbX4LAPUpDn-ImzThFVFjHpQmvZB6GJecZNLD--ehdp6Km5gsQ=w663-h884-no
