No recommendations on nets, but I open the glass so I don’t lose any items out the back. Keep us posted if you find anything.
I've got one of these:
https://www.amazon.com/dp/B075B6RVYW/
In addition to the adhesive backing I drilled the supplied screws into the interior plastic trim to secure the mounting points and have had no issues with anything coming loose.
Most of the time the bottom stays attached and I keep the top detached and stowed under a weathertech cargo liner. It's been handy and is certainly cheap enough.
This really was piss poor planning on Fords part. I found this one on Amazon: https://www.amazon.com/MICTUNING-Th...Z6JE1Z06DVH&psc=1&refRID=6PTKT5K00Z6JE1Z06DVH (Wow that address was longer than I tought) I measured my 08 Limited. The rear width is 50.25" so this should fit with minimal stretching. It's on order and once it's installed I'll do my best to update this post.
