duneslider
More miles, more towing, new tires, I still prefer the bilsteins to the CCD.
Of you weren't going stealth, I'd say it wouldn't be a deal killer. However, he sport suspension on Top of 22in wheels without any adjustability, no thank you.I’m in the same boat. 23s with .9% or 1.48% interest in my area. Lot of stealths Do Not have CCD. This will be a pavement only vehicle.
Looks like there are 0 stealths in my area with CCD. Might have to settleI’d try as much as possible to get the CCD option. In sport mode, the floaty feel is really all gone and nice and tight but then you can go back to normal mode for a super smooth ride. The suspension seems to be more on point overall. I wouldn’t let it be a total deal breaker but if you don’t get it then plan to be changing the shocks to a better brand like Bilsteins since the non CCD shocks are of pretty poor quality. Other thing to look at it what brand tires are on the non CCD trucks. Lack of CCD and Hancock tires is a disaster.
I’m guessing the strut info is all on this forum? It seems bilstein is the way to go . Will it have stock ride height ? WhichWheel size and tire choice are also big factors. With the 22” wheels you want it. OEM stock tires seem to be “meh” at best as well on most setups. Getting the Hankook tires off for BFG AT tires on my 20” wheels made a huge difference for me. Maybe get what is on the lot, but expect to want to swap out tires/wheel size/struts (and/or) in 6 mo to a year? I just remembered chucking the garbage stock tires after 10K miles and even my wife being amazed what a big change it made, and she rarely cares about road handing and road feel.
i plan on sticking with 22s so I’ll have to do some more research in tires. In the test drive today I noticed it’s on the firmer side but not bad. My raptor is more plush but thag has big tires and suspension. But it’s also body rolling much more. To keep stock heights which struts are people going to? Anyone have a forum link ? Are they full coil overs or just struts ?Wheel size and tire choice are also big factors. With the 22” wheels you want it. OEM stock tires seem to be “meh” at best as well on most setups. Getting the Hankook tires off for BFG AT tires on my 20” wheels made a huge difference for me. Maybe get what is on the lot, but expect to want to swap out tires/wheel size/struts (and/or) in 6 mo to a year? I just remembered chucking the garbage stock tires after 10K miles and even my wife being amazed what a big change it made, and she rarely cares about road handing and road feel.
Can the bilsteins be kept at stock height for fronts and rears if I decide to switch to them? The 5100s correct ? Any downside to them?More miles, more towing, new tires, I still prefer the bilsteins to the CCD.
I kept mine at the stock height, the wife didn't want to go bigger. The bilsteins are more firm than the stock suspension but I personally thought it was a much better ride than the stock xlt shocks which I thought were way too soft. The bilsteins also seemed to control body roll much better and were much more capable of dampening bumps with heavy loads. My current platinum with ccd doesn't drive as nice as the xlt with bilsteins in my opinion. One big example is with my big bike rack on the back full of bikes (7) the back end gets bouncy and the ccd just doesn't do as good of a job controlling it. I still got some bounce with the bilsteins but not as much and it felt more controlled. Even in sport which should make the shocks stiffer it doesn't feel as good as the bilsteins. I am planning to get swaybars but I am not sure how much of the issue that will solve but it should help with the body roll we get in the back mostly. I really do feel like the ride in my xlt was better than the platinum, I would go back if I could.Can the bilsteins be kept at stock height for fronts and rears if I decide to switch to them? The 5100s correct ? Any downside to them?
What he saidCCD is definitely a
Plus if your not into modding it. Long road trip rig definitely CCD.
If its going to be a dirt rig then keep it simple skip ccd
Depends on whether the Stealth model has the standard Stealth package or the Stealth Performance package.is there a difference between limited stealth suspension and just regular limited suspension? the stealth is pretty stiff in the rear. would like to soften it up a bit. does limited have softer susp then the stealth or are they the same?
for 2022+ both 303A and 304A have "Sport-Tuned Suspension".
For sure if the shocks on the regular limited are softer I’ll just swap them no problem I’m sure the cost isn’t very high.Probably slightly firmer shock tuning. You mostly feel it in the non ccd trucks from what it seems from buyers on here but everyone with the 22s and no ccd complains about the ride on any road not on the highway.
