bchampion
I bought my 2018 brand new off the lot back in December 2017 and it did not come with the heavy duty tow package. It's a 4x4 Platinum Max. According to the Ford factory towing specs, the max I can tow with this setup is 6000lbs. Well I would like to be able to tow at least 8000 lbs. The factory HD tow package includes 2-speed Automatic 4wd w/Neutral tow (4x4), Radiator upgrade, Pro Trailer b/u assist, 3.73 limited slip Diff, Trailer Brake controller, Trailer sway control which allows the 4x4 Max to tow 9000lbs. I recently added the trailer brake controller and I asked my dealership if they could change the ration in my rear end to 3.73. They said they couldn't do it and it would void my factory warranty. Well I'm not worried about the warranty and rear end ratios can be changed by any competent mechanic. The upgraded cooling is probably just a larger radiator which I'm sure I could order from Ford parts. The big thing for me is 3.73 rear, I'm not so concerned about the other items in the HD tow package and changing out the rear gears would sure be cheaper than buying a new Expedition.
