Crazywhiteboy94
I have new alt even though old bench tested good new battery new fuse box because of fuel prob an it is the right model fuse box still no charging from alt I have not seen any clear answers on fixing this
VOLTAGE DROP TEST to make sure all cables and connections are good.I have not seen any clear answers on fixing this
Voltage Drop Test is testing the connections without having to take them apart and you can work your way right to the problem.I have yet to find solution only getting about 6.7 volts out of prong on alt plug new alt the old one was doing same I unplug it no change in volts to the battery
