Check Brake system lights
Church
Louisiana
I am getting a check brake system light when I go over bumps. it is not all the time but has happened on numerous occasions. this will normally cause my radio to cut out and restart. I drive a 2007 expedition with 153k miles.
deweysmith
Montreal, QC
Sounds like you've got the mother of electric shorts. I would get started looking for corrosion or bare wires around any and all of the main harnesses under the hood.
stamp11127
Temple, Georgia
The two problems are probably only related due to the bumps. I would suspect the warning lamp isn't causing the radio to power off.
Diagnose each problem separately using the wiring diagrams for your year.
iimagine
2016 EL XLT
Can't figure why the radio shuts down but I had an F-150 a while back and the brakes had a very slow leak. When the brake fluid would get a little low, as I would go over RR tracks or down the bumpy dirt roads, the brake light would come on letting me know I needed to add fluid. I just kept a bottle behind the seat.
C
Church
Louisiana
Fixed the problem. Had a lose connection on the battery lead going to the positive terminal. wing nut was not fully tightened down causing some wires to be lose.
