Chirping Sound from Engine
2015owner2015
Northern California
I have a 2015 Expedition with 151K miles. Can anyone identify the cause for this squeak/birdy noise? Seems to be coming from the general area of the fan belt.
No issues otherwise, drives perfectly normal.
Possibly just a belt or pulley issue? Or could it be a pump or turbo issue?
Link to video below
GlennSullivan
NY & FL
Belt tensioner, water pump pulley, AC compressor clutch. The metallic noise is concerning. I assume the noise increases in direct proportion to RPM, correct. You could slip the belt off and manually turn each to see if you can hear or feel the problem area.
2015owner2015
2015owner2015
Northern California
Water pump is an interesting thought. Another symptom I've been seeing recently is the fan intermittently stepping up to higher speed even when the engine is cold and outdoor temp is cold. Could this be related?
99WhiteC5Coupe
If you hear the radiator cooling fans stepping up to high speed, then you could have a high engine temperature due to low engine coolant, or a bad temperature sensor.
eddytheexpy
Phoenix, AZ
Did you get the stethoscope yet? I feel like you haven't because you would have at least found the area it's coming from if not the exact component within 5 minutes.
Harbor Freight - Mechanics Stethoscope
It's not even $10 so go get one and post a pic of the area you're hearing the noise assuming it's not an obvious component like the tensioner or idler pulleys. Just remember to not touch the probe to any surface that's moving unless you want to be deaf for a few minutes (did that last weekend while was I on autopilot helping buddy out with his Tahoe :p). The only thing we can tell from our shade tree is that sound is coming from something that's spinning so you've narrowed it down to pretty much everything haha. We're happy to help but we need a little more diagnostic info from you.
