Irish Medic 51
Ok So I had a fuse blow on my 2004 Expedition I removed the fuse box and noticed that relay 203 had the cover missing I replaced the fuse for the radio and replaced the cover on relay 203 and thought I smelt something like when a wire gets overheated I went to start the truck and nothing just a click from the fuse box at the starter relay. Went and bought a new 203 relay and starter relay and replaced them both same result after replacement Towed the truck home replaced the starter thinking that that was the issue and the same result Just a Click.
I have power to everything else and the starter will start and turn over when you go and jump the starter solenoid. I have looked at every fuse in the fuse box and they are good even the 30 amp pink fuses.
Any help would be great is there a secondary fuse box under the hood? Is there another solenoid location
Do I have to replace the fuse box? Where do I start looking I am lost? Also you do not hear the fuel pump engage when you turn the Key I have checked all fuses what am I missing here?
Please HELP !!!
Please HELP !!!
