KimberlyH
I have a couple of things going on with my engine coolant.
In the winter, when the ambient air temps are cold I have a horrendous cold water leak. I'm talkng pours out the bottom of the engine. It comes out on the passenger side right behind the front tire. No where near the radiator, reservoir, water pump etc....
When it warms up, it stops leaking. All the shade tree mechanics here have told me to just put stop leak in it and call it. One pressure tested it and still no leak.
Now that it's gotten warmer the cold water leak has pretty much stopped. I need to get this fixed this summer so we won't have to deal with it next winter. I have been told everything from head gasket to hoses. No sign of water in the oil. Nobody wants to find it. ( because obviously I am not rolling in the dough) Any ideas welcome. My next plan of attack is to buy the UV dye and see if I can find it that way.
More current problem is getting warm while driving. Not hot, just warm. When you pull over to check the water etc... It cools down which is the complete opposite of what usually happens. Some days it doesn't do it at all. Changed the heater control valve because it had a smell leak. (Vaccuum line not hooked up). Bad sensor? Thermostat? Water pump?
As I stated in the welcome thread I am definitely not a mechanic, just a parts replacer if someone can point me in the right direction.
Any help would be appreciated.
