Connecting a Rad/Sat to the overhead console
snowsurfusa
Orange County, CA
I want to direct wire my radar detector into my overhead console so I don't have the wires always hanging down. What is the best way to do this? Any help would be greatly appreciated. I have a 2003 4x4 XLT with the long overheard console(direction/temp, glasses/garage, dome light).
thanks,
dtd07
Oregon
you can tap into the direction/temp power..this should be a switch power, but becareful some radar detector do not run directly off of 12v (14.5v engine running). the plug that comes with the radar is also a voltage step down. try google "hardwire for radar detector". If your radar has the step down build into it then you are fine. Double check.
Use a volt-meter and measure the voltage with the key on/off position.
Newport News, VA
i have beltronics radar and need to do the same...i bought the hardwire plug for it...just havent dont it yet....for me i just need to simply tap a -/+ then plug in...
Newport News, VA
just havent done it...things to do list after 15 JUN 12...baseball will be over...lol
Eye_Traveler
Memphis, TN
Check on eBay for direct wire kits as well. Haven't put one in my Expy yet (wife drives it) but did put one in my SportTrac. Purchased a direct wire harness with in-line fuse that is about 12" long total made specifically to tap into overhead console or powered rearview mirror. Mine was for an Escort 8500 but they offered special made cords for all types. Less than $10 with shipping included. Simple install.
