converted XLT to LED
Molaf
Merica
Mine have dark spots too but they don't bother me because it's like the first 10 feet in front of the car.
KSC 2019 XLT
DFW
Per the owner's manual, there are vents in the housing so moisture is expected.
Drew47000000
Daytona Beach FL
Not that I would ever condone putting bulbs that put out 2x-10x the light output into the same housing, it sounds like you could use some capacitors. The LEDs should be using significantly less power than a halogen ever would. Maybe there is a quick dip in voltage as the engine turns off? This sounds weird...
I hate the flicker too! Please let me know if anyone has a solution with capacitors. I notice it upon starting up at a red light or somewhere the auto start/stop functions. I went with LED bulb swap out as well and would love to resolve this.
Molaf
Merica
If yours are flickering at other times other than ignition after start/stop, then yes, you will need capacitors. What make of LED bulbs are using?
Diverdown
KC
I’ll have to do this too
