Capt Cutlass
I have an expedition and a navigator.... The problem is with the navigator.....
Heading home last week truck cut out and died.... Cranks strong but will not start.... Thought maybe the fuel pump so I pulled the gas tank and fuel pump out... With a light probe I tested to see if there was voltage at the pump, there's none... Tested for power at the intirtia switch, none.... Half the fuse in the fuse box (under steering column) have no power..... Fuel pump relay slot has power to one slot while most of the others have power to 2 slots..... Prior to this both back windows and front passenger window all stopped working.... Has anyone else experienced this? Is my wife's truck..... Just picked up a volt meter, but have no clue how to use it..... Just took out the fuse boxes from under the hood to see if any bad wires are visible.... Can't seem to find any..... Was going to buy a new pump this payday, but $300 is a waste if it's not the pump...... Any suggestions would be great, thank you.....
