Cross compatibility on 07?
cjbuckeye
Youngstown, OH
I have an 07 XLT and have the famous corrosion issue on the hatch, quotes are very high with the labor to prep and refinish the aluminum issues to make it last....
I found a hatch / lift gate in excellent condition at a salvage yard but it’s an 06, I knows it’s a different generation but it looks identical to mine, does anyone know if this will fit and plug into the harness?
Thanks!
Adieu
SoCal
What harness? Buttons for glass and lock + rear wiper?
Just cut your own connector off and use that if it don't (best prevent it from locking closed before you verify that all other functions are working correctly)
cjbuckeye
cjbuckeye
Youngstown, OH
Good point, I can do that, just wondered if anyone knew about the hinges and latch, etc
Mine has one, just changed it last month. It was under dash just in front of diagnostic port. Your probably right with it sharing the same signal relay, or module. When my flasher relay started failing, it was right after I started using the 4 ways. It got so bad, even the regular signals stopped working after about 6-10 flashes. New relay and all is normal.
Cj your going to have a tough time on finding a member that did the swap. Most just repaint. Why not do the sanding and prep work yourself. It's not that hard. All you'll need is grease prep to get off all wax, and gunk, sandpaper, the proper primer for aluminum, and if you don't want to spray base coat /clear coat yourself, pay a shop or individual to do that. The mobile dent repair guys are usually way cheaper than a shop. They don't have the overhead, sometimes close to half off. I wouldn't [emoji205] around with chopping and rewiring plugs, you can open up a whole new electrical issue. If you want the one from the wreckers, have them use their cross reference guide. It will tell you and them if it fits, and plugs up.
cjbuckeye
cjbuckeye
Youngstown, OH
Thanks!
Well if it was me, I like to a job right the first time, so I don't care for spray cans. Dupont makes a nice 2 part etching primer called chromax. Its got an activator that you add to the paint. Depending on what color primer you have underneath your color coat, you'll find that out after sanding off old paint, that's what you want to buy. Keep in mind you'll need a spray gun, and a compressor. The spray gun you might be able to rent from O'Reilly's or Auto zone or borrow from a friend. The compressor might be tougher. The others will say just rattle can it, but it might flake off like factory. I've used in the past their green etching primer on quite a few fox mustangs with great results. That's my 2 cents. Hope that helps.
Oh forgot the price is around $75.00 for a quart with activator. Your labor about 4 hours work time, whatever that's worth to you.
cjbuckeye
cjbuckeye
Youngstown, OH
Well that beats the $1,000 quote with prep, materials , total labor..... wow!
Now my rear fenders are the other problem...
Thinking body Shop best for that.
I recently bought the car and it’s an excellent family car and tow vehicle for our camper and negotiated down due to the rust issues but I’m finding out I didn’t enough unfortunately. Runs solid, a lot of preventive maintenance done, coil packs, plugs, fluids kept up with, just need to make the body nice and I plan to keep for a long time.
Those wheel wells or “fenders” aren’t too expensive to have re worked. They will cut out past the bubbles and weld in new. Had my passenger side that was getting ugly replaced after some damage.
cjbuckeye
cjbuckeye
Youngstown, OH
What did it run you? I have two one from a ford dealer , one from a shop and 2k +! I’m told the hatch / liftgate is about half
I took it to a body shop for the partial wheel well replacement it was $700. I had the passenger side replaced, although the bubbling wasn’t as severe as yours. They cut out the problem area and made up and welded in a new piece and painted/blended. Can’t even tell anything ever happened. It was a little cheaper as well since I handed the owner cash.
Man you guys pay half of what the Bay area would run to do a job. They wanted $1400.00 just to pop out a small dent and paint my right front fender and part of passenger door. Material to repair and paint that fender/door is under $200.00. base coat/ clear/ primer, and sand paper. Lot of labor charge here. I have 2 small dents that probably will never get fixed, and a $1400.00 check from AAA that got deposited 2 years back.
Adieu
SoCal
With fenders, why not take out the rust prime it and just slap some aftermarket cover over it? Mindblanking on the name, but you know what I mean, the things rednecks bolt/glue on
iimagine
2016 EL XLT
Fenderflares?
Redneck at your service
iimagine
