So, I recently bought a '99 expedition XLT with the triton 5.4L for a great price because it was running rough (2 misfiring cylinders and rough idle) and had CELs. So, I hooked it up to a OBD II reader and it threw 4 codes: P0171 (Bank 1 System Too Lean), P0174 (Bank 2 System Too Lean), P0302 (Cylinder 2 Misfire), and P0307 (Cylinder 7 Misfire). I found the vacuum leak and I'm 90% sure that is why I'm getting the first 2 codes, what I'm concerned with are the 2 misfiring cylinders. I took the COP off of cylinder 2 and tested it with an ohmmeter like it listed in the Haynes manual (.55 ohms across the two connections on the top of the COP) and it passed that test. Next step is checking the spark plugs. Any thoughts on what else could cause these 2 cylinders to misfire consistently? Or could the coil still be bad even if it is within specs for resistance?
