doesnt have any go
silverbackexpo
rockland county ny
Hey guys im back after fixing 95% of the problem brutus had now he's acting like he doesn't want to go anywhere when I step on the gas. From what I have gotten from other convos on here is that I mite be clogged catalytic converters or the sensor that is after the mass air flow sensor. Guys please tell me what u think it could be.
semperfi96
Huntsville
sounds like one of the 4 cats are giving you a problem, I just went thru the same thing. had 2 cut out completely then just went with 2 only. seemed to have been what I needed. Mind you I am in a state with no emission laws too.
silverbackexpo
silverbackexpo
rockland county ny
Also when it gets to operating temp that's when it starts to run like it doesn't want to go anywhere. But when's its cold it runs good.
silverbackexpo
silverbackexpo
rockland county ny
Do u know which ones would be clogged also is there any one in new York that knows where I can get o2 foulers because I might jus get rid of them an go true dual with a x pipe.
semperfi96
Huntsville
you can leave the o2 sensors due to where they are, there are 4 total 2 small ones and 2 large ones they are attached together basically by 2' if you do one side the back pressure on the other side will not be the same. its off by 4 pounds of pressure and could cause problems.
I would go ahead and get all 4 cut out , cost me 60 per side when I did mine. then just welded striaght pipe in place. and never had to touch the 4 o2 sensors
Exia
Kentucky
One word.... "Borla"
Those sound mean, cause flowmasters are so overrated anymore...
As long as you can find a shop to cut them off, you should be fine, but if you are worried, the SES light will be on then buy a HF Cat, they cost around 40 bucks
semperfi96
Huntsville
Borla are great mufflers. but they all give pretty much the same sound, I just put a flow on mine and love it.
silverbackexpo
silverbackexpo
rockland county ny
As of today 8/26/12 I had to go upstate to peekskill and I had to go up the mountain. As I'm going up the mountain I can smell gas. I'm starting to think its not my catalytic converters that r clogged.
semperfi96
Huntsville
yep, the first 2 small ones, smelled like it was running rich as all get out. and when I cut it off too.
silverbackexpo
silverbackexpo
rockland county ny
Ok guys this is what I found out from summit. They have spacers that they sell that will change how far the o2 sensor is in the exhaust flow. From what they explained to me if I run straight pipes it will not throw the cel. So I think that's the route I'm goin its cheaper an I have the exhaust pipes already.
Now for the kicker. Should I go with a x pipe an 2 super 10s or a Di/do. I would like to hear opinions on this.
