Hello guys. It is time to move to other issues one of which is the door locks.
98 Exp XLT 4x4, 5.4L. All doors will lock and unlock with the key fob. The drivers door switch will lock all the doors but it will not unlock any doors. After driving and I need to unlock the other doors to let someone in, I have to shut it off and pull the key out to use the key fob.
So far I have replaced the driver door switch and looked for obvious wiring problems. I got a new relay but don't know where it is on the 98. I have read up and there are 3 possible locations for the door relays. 1 is in the dash under the oval panel on top of the dash below the windshield. 2 is in the driver's side passenger door. 3 is behind the driver's side rear compartment panel above the rear wheel well area.
If the new relay doesn't fix it then I will have to trace some wiring but either way I have to get to the relays to do. So if anyone can tell me where the relay is and have any other insight on the problem I would appreciate it. Thanks.
