Easy way to get the back plugs out of an 01 4.6l
cdn_fenix
Oshawa
Hi there,
I'm having dificulty getting to the bolts on the coils on the last 2 cylinders on the drives side. Is there any
way to get the coils out with out having to remove the fuel rail.
thanks in advance
Bedrck47
Elizebethtown, PA
Welcome to the forum
Why fight it loosen the rail and if needed remove it Just make sure that you don't loose the O-rings
docraymund
philippines
You could loosen it first with a 7 mm open wrench then take it off by hand. Just be careful not to drop the bolt. Yeah and snake your way into it. Use a foot stool to get more leverage.
