Eddie Bauer frustration
Kevin Huyler
SAN ANGELO, TX. 76903
I have a 2000 Eddie Bauer with 250K.
It is having intermittent starting issues.
It has a new starter, new cables, battery checks out and new solenoid.
It will start a couple of times then I have to disconnect both battery post and the solenoid, reconnect them and then it will start a few more times.
Has anyone ever heard of this type of problem?
Hamfisted
Ft Lauderdale
Yeah that's what it sounds like. Classic wet fusebox / relay issue. Disconnecting power resets the relays. Look at the kick panel area under the dash and see if you see evidence of water getting in. Do you have a sunroof ?
Machete
My Rig. 2000 EB 4x4 5.4L
Illinois
I did all those replacements. Battery, starter, then the friggin alternator gave out.
They said there’s a wire dongle off the alternator that should be replaced at the same time I went ahead and did it. It was corroded.
