Engine cover question
Sal Minella
Colorado
Hey everyone,
I just had a 5.4 replacement engine installed with new engine mounts and the shop claims it never had the plastic engine cover that goes bolted on top with the ford logo etc. the motor shakes the truck a lot and im wondering if the cover helps with stabilizing the motor up top ? another friend told me it would and it kind of makes sense but what is your opinions. motor was from the same year etc. same size everything 2000 xlt 5.4 triton
S
Sal Minella
Colorado
thank you so what could be the reason if the motor mounts are new and tightened at spec ? It runs fantastic I just Don t understand the shake.
laiod
United States
It almost sounds like a misfire to me. Does the truck run smoothly? Or does is **** around when you're driving it?
S
Sal Minella
Colorado
the truck runs smooth and mounts and bolts are tight and the shaking is on the start from a stop then its running fine
proftomda
georgia
I agree take it back to the installer. The shaking you describe could be many things from driveshaft to internal engine balancing.
