Expedition Shuts Off While Idling
Essdot757
I Have A 04 Expedition Nbx, I Recently Got My Truck Diagnosed And They Couldnt Give Me A Definite Answer To Why My Vehicle Was Cutting Off While Idling. As Long As My Vehicle Was In Motion It Was Fine But When I Came To A Stop Light It Would Rumble And Shut Off. I'd Start It Again And I'd Be Fine. This Would Happen No More Than Twice Within 10-15 mins.The Auto Shop Did A Fuel System Check And Checked For Vacuum Leaks. I Had Codes Come Up For O2 Sensor. They Also Said Those Were Fine. The Technician Suggested Changing The Mass Airflow Sensor Based Off Of Experience. MAF Are Expensive. I Need Helping Narrowing Down The Problem I Was Told It Could Be A Number Of Things And This Could Be A Costly Fix. Thanks In Advanced
Hamfisted
Ft Lauderdale
Any strange other idle speed issues ? I was just wondering if it might be a dirty or sluggish idle air control valve. When you come to a stop after driving does the motor drop down to a very low idle ( <600 rpm ...) and then die ? Try cleaning the throttle body throat and butterfly, and the idle air control valve ( you can spray some foaming cleaner through the idle air intake tube .... )
Amsoil's Power Foam is a great throttle body cleaner ....
E
Essdot757
Yes It Does Drop Down Like You Said, I Cant Recall The RPMs.From What I've Researched So Far I Could Just Clean The MAF Sensor And Be Ok. I Will Also Try This Thank You For Your Suggestions
