Factory DVD or aftermarket
Dice Roll
Craps Table
Salesman tried to convince me the factory offering wasn’t as good as his “Ford aftermarket” setup. Two issues I have with that are he quoted it being about the same price and I trust the factory unit will work easily from the dash, last, etc. also bothered he didn’t know much if anything about it and how it was controlled, and it wasn’t listed on the email quote for the truck I drove that mostly matches the specs I want. Still could be a great deal for me if a dvd arrangement comes together.
Then on here I’ve read comments that the factory one isn’t so good. Do they not work well?
I have kids that are too young to operate an ipad or even hold one if I turned it to something for them.
Aftermarket would open doors to a trillion more trucks, not something I want to chance though if the factory provides a decent setup.
George R
Arizona
the factory DVD players will most likely be integrated into the infotainment system. Any aftermarket unit will NOT. This does not mean that you can’t get a quality aftermarket unit. alpine makes a pretty decent overhead unit for less than 1k dollars.
anything the dealership tries to sell you will be aftermarket as well and have the stealership premium price.
AAOO
We are satisfied with the factory FES. Could there be some improvements yes, but FWIW it functions well. This is one reason I had to send my dealer out of state to locate the vehicle. I didn’t want their aftermarket unit they wanted to sell me.
Mothnuts
Kansas
We don’t care for the factory rear entertainment in our ‘19 Platinum for our 4 and 1.5 year olds, but that being said we ordered it again in the 2020. I initially was going to go aftermarket, but other then iPads, I didn’t find a great solution. I was all for iPad’s, but that’s a battle with my wife that’s another story. The factory system is just not user friendly to control from the front seat. Either my wife climbs in the back, or they just have to wait until we stop somewhere. The one in our Tahoe was controlled from the front, and would start and stop by just opening and closing it.
AAOO
This. PIA to control if you have kids that are too young or just a dufus. Luckily I bread some Mensa level brats.
Mothnuts
Kansas
I reread your original post. The factory rear entertainment is completely independent. It only connects through the Sync in your dash through Bluetooth when you want to use the car speakers instead of the headphones. You can have a factory Ford setup just by replacing the headrests with the other ones. I wouldn’t let that be a deal breaker on finding a certain vehicle, as it can easily be added to any of them. I’m guessing the power leads might already be there to plug into.
D
Dice Roll
Craps Table
Check out some of the threads already on this topic. There’s myriad opinions and hints. Here’s one:
2018 Rear Entertainment Initial Feedback
https://r.tapatalk.com/shareLink/topic?share_fid=20862&share_tid=34199&url=https://www.expeditionforum.com/index.php?threads/2018-Rear-Entertainment-Initial-Feedback.34199/&share_type=t&link_source=app
thanks. I must’ve screwed up the search as it kept pulling up random things with the letters in out in and not like it was a phrase.
D
Dice Roll
Craps Table
I wish these people selling 70k+ vehicles understood all this. I’ve asked several, I mean several, dealers about adding the Oem setup and none think it’s possible. I’ve even pointed out the wiring has to be a plug in or it wouldn’t work on an assembly line. I think the biggest thing might be the head unit needing switched out if they all don’t support the menu necessary. Without more in depth knowledge of it, I dunno. But somebody in the business everyday should.
D
Dice Roll
Craps Table
So this all makes it sound like the dvd goes into the headrest and not through the dash? Seems nobody around here likes kids so I have to drive way off to see one in person. I’m used to putting it in the dash in the minivan. often easiest going down the road to just eject and reload rather than fool with the menu bs.
scottdm
Western PA
Our factory RES in our Toyota Sienna is way more intuitive and easier to use than the Ford RES in our Expy. The Toyota allows parents to insert a disc in the front dash player and control via the headunit. The Ford RES has no wired audio connection to the front headunit and requires bluetooth audio to connect to the RES which is a pain. Every time you cycle the ignition, it has to relink, etc (think stopping to get gas with kids in the vehicle, etc). Our kids don't like to use the IR headphones, so we prefer to play the audio through the vehicles speakers. Discs also have to be inserted into the driver's side headrest, and this becomes an issue if the drivers seat is too high since the disc doesn't have space between the top of the headrest and the ceiling. At least you can burn files to a USB stick and avoid the discs altogether. Overall, it's a very poor implementation and Ford should be embarrassed. Obviously the people that designed it have never tried to use it on a road trip with kids in the vehicle, or worse yet they just don't care about good design and assume it's good enough.
nobrainer
Bartlett, IL
I have it in mine (one dealer within 20mi of my house had one with the OEM RSE), my 7yr old is able to run it for my 4yr old (one remote can control either screen). they use headphones. The biggest problem for me was finding the right format to put videos on the SD card. I have it setup to the bluetooth for the audio, but never messed with trying to figure out how it worked.
Worst case, you can hook up some sort of iPad to the HDMI in, keep the iPad up front with you and control what's playing if your kiddos are younger.
aggiegrad05
North Texas
From what I can tell, if you’re buying the system for adults or kids who are old enough to control it on their own, it’s a pretty good setup. If, however, you’re buying it for smaller kids who can’t, it’s a waste because you can’t run it from the front as you can in many vehicles.
Because it can’t be run from the front, and because it cost $2k, is why I just bought cheap DVD players from amazon to strap on the headrest...they’re essentially the same thing; the benefit of an OEM system is SUPPOSED to be that it’s integrated into the vehicle and can be controlled from the dash.
Bow512
TX
A few notes from my experience:
1) A separate Bluetooth speaker is the best option. The kids can listen in the back and I still have full control of what I want to listen to up front (fade the speakers to the front). It connects on its own every time we turn it on.
2) The Expy system is better than the Navi as the Navi has no DVD player
3) If you can take the time to rip movies/digital copies to an SD card, it will make things easier.
4) My 6 year old can run it on his own. We just have the 4 year olds screen mirrored to his.
5) Worst case you can use the Ford Play app to control and even watch what’s being played on a separate phone or tablet. I have used this a couple time to control stuff from the front seat when the battery was dying on the remote.
All these work arounds shouldn’t be necessary, but it’s what I’ve found to be the easiest when dealing with this system.
AAOO
Everything is controlled from the rear and the drivers side headrest is the master device with the dvd slot, card reader slot, hdmi, and usb.
NukeLife
Charlotte
What Fordplay app are you referring to?
Bow512
TX
Never mind the link I tried to post didn’t work.
Said not available in my region. I don’t know what’s up with it not being there anymore.
D
Dice Roll
Craps Table
Ok so ford play sounds like a solution here. My wife could run that on trips pretty easy if we load one before taking off or have an Sd card. Or maybe change dvds on the fly...
that is if it works. That last post makes it sound like it isn’t working anymore?
is this like ford pass or whatever you have to pay to use after the first year?
