jasonlmarsh
This was my first attempt at retro'ing a set of headlights, so it is a pretty simple & cheap setup. I tried to stay on the cheap with everything, just in case I screwed it up...
H1 mini's I scored on Ebay for $50. I painted the shrouds satin black
Projectors installed in the reflector. I had to do a little dremel work in the bulb socket area to get the projector to sit properly.
Mounted up, about ready to reinstall the lenses. Fortunately I had a fairly new set of aftermarket headlight assemblies. Removing the lenses was super easy, 10 minutes @ 200 degrees and they pulled right off.
Lenses are back on. While I was in there, I decided to throw in a set of $20 Autozone white LED's to use as DRL's
Here they are with the DRL's lit up.
Output shots:
For comparison, here's my wifes Lexus RX350 low/high
Here's mine with 35w HID's @ 5000k
And mine again with 55w HID's @ 5000k
Now I just need to figure out what to do with the fogs. Currently I have a set of 35w @ 3000k HID's in the reflectors.
Output shots:
