Front End Rebuild
JoshA77
Bozeman mt
I bought my ex that had been wrecked in the front and manages to pop everything perfectly back in position. However most of the front end plastics were destroyed so I bought new headlights, header panel, grill, and bumper cover.
But does anyone know if you need the " Baffle" or "grill mounting panel" (ive seen this piece called both)
to complete my rebuild or can I forgo it?
This is the piece...
Bedrck47
Elizebethtown, PA
What are you referring to as baffle? or grill mounting panel?
Are you referring to the panel that fits into the header panel opening??
Bedrck47
Elizebethtown, PA
The purpose of that piece is to direct air thru the radiator I left it out when I did my 04 but have since obtained that panel and will be installing it when the weather gets warmer I have not had any problems with it being out and I don't think it will be any problem in the colder weather But I would want max air flow during the hotter months or when towing
JoshA77
JoshA77
Bozeman mt
Thanks Bedrck, I just wasn't sure if it need to be there for the grill and bumper to mount up. That's cool your from Mount Joy, I moved from Hershey about 2 years ago.
Bedrck47
Elizebethtown, PA
Nothing mounts to it It mounts to the header panel with push in pins
Hershey is changing as id the rest of the area Never bee to your state Its one of three I have never been in YET
