front end wobble
04nbx
delaware
I have an 04 nbx expedition that gets a wobble every time I hit a pothole or even turn somewhat abruptly... the truck has 150k on it and this seems to be a pretty common issue, so I was wondering if anyone who has had this problem can point me in the right direction before I start replacing random stuff....also it does it right around 50 mph....
Thanks in advance
Bedrck47
Elizebethtown, PA
Rather than replacing random stuff as it sounds like you do your own work I would spend a few dollars and take it to a good mechanic and have him go over the front end and let you know what it needs.
04nbx
delaware
Yeah that's my plan I just wanted to see if it was a particular part on these trucks that cause since it seems as a common problem..thank u
Hamfisted
Ft Lauderdale
Like Roxy said, any good alignment shop should be able to pin point the problem pretty easy. On my '03 the main culprits were the lower ball joints and the inner tie rods. Those are the high wear parts on the front end.
-Mike
04nbx
delaware
Thank u I will keep that in mind I already sent it to my long time mechanic I'll make sure he gives it a thorough look
04nbx
delaware
Anyone else? My mechanic took a look at everything and said everything seems to be in good shape... He is gonna replace the struts and shocks because it seems that most likely those never got replaced but any more input will be highly appreciated....
Thanks in advance
