Ive never looked at the actual service instructions but since the flap still seals tight I would Just slide something in there to keep the flap open slightly.Instructions tend to say open gas cap so that some pressure thingie keeps it from spitting fuel at you....what do you do on capless?
Thats what I would do But like I said I've never read the service manual and have never removed a fuel cap while doing a filter... LolSo just stick in whatever funnel you use to pour in additives?
It's only makes pressure when the pump is running so the only has you'll get it what's leftover in thr lines. I'll normally just drop a small bucket underneath the connections I working with and let the gas st in into the bucket. Pressing the Schrader is the easiest way to confirm youbhabe no pressure but you'll still have liquidWhat did you do instead? Pinch off the line with something?
Is there anything you can royally screw up on a Triton 5.4L filter change? Cuz I'm coming from a diesel bimmer, and on that thing, if you didnt fill up the fuel filter with diesel or an additive and didnt purge the system of air bubbles, it could supposedly royally jack up an expensive high pressure fuel pump.... or something. Not sure if any of that is relevant to gasoline systems in general or the Triton in particular though.
Anyone?
thats why I suggest relieving it at the schrader at the fuel rail which is the proper way to do it.
but whatever floats your canoe...
Anybody got a roadmap where to find all this shit?
Youre making it sound like everybody knows what a shrader or a fuel rail is...
the fuel rail is located on the top of the engine the Schrader valve is located on said fuel rail its made out of pure unobtanium
If you open the hood you will see the engine
take it from there
ha my wife says I have no memory leftI see what you did there. Not many things I see online actually make me laugh out loud.![]()
