wow! your awsome. thanks!!!!!Do you have a heat gun ( hot air gun...) ? You can remove the end from the line with a heat gun ( soften up the line and pull the fitting out...). DO NOT USE ANY KIND OF FLAME TO HEAT THE LINE !
Then NAPA or one of the other autoparts stores (even Advance Autoparts...) has the replacement fittings that will fit the fuel filter ( 5/16" pipe...). But take your new fuel filter, or one they have in the store and make sure the fitting clicks tight on the filter, before you bother to re-install it on the fuel line.
Something like this....
https://shop.advanceautoparts.com/p...-in-nylon-w-90-degree-bend-800-123/10191169-p
