krakoosh
I have an '03 5.4. I had to repair the relay in the fuse box but before that the pump was replaced, bad job of troubleshooting for sure. I now have a lean condition and mechanic says he's only getting 38lbs at the rail. The pump has been in since January working just fine. Problems started about 1 month ago with a slight miss that felt like the transmission slipping. It started to take a hair longer to fire up and finally threw PO171 and PO174. Replaced PVC hose assembly. It now takes considerably longer to fire up with PO171 coming back which is why I took it in for a look. He's saying bad pump. Has anyone ever had to replace the pressure regulator? Is that part a works or it doesn't item? I didn't check the pressure after new pump was installed so I can't say what it was at the rail then.
Just wondering if anyone has some idea where to go from here.
