The first edition expys have a pull down panel for the inside cab fuse box. Theirs a 30 amp fuse in the fuse box under hood #601, that box is fun to get open. Inside cab theirs a 15 amp fuse #14 for power windows. If only one window stopped working, my guess its either the switch, or the motor itself down in the door failed. Drivers window gets used 10 times as much as others. Pop the window switch panel and check the drivers door switch with a continuity light. See if you got power to the switch, then rock the switch to open and close, see if corresponding terminals light. If they all do, its probably the motor. Keep us posted what you find. Moose.
