I have the lowly sync system which is really fine for my needs in comparison to what the big sync screen does.
I would like an actual GPS app (Gaia) option and an ODB2 scan tool display. Neither of which are available to use with the sync system.
Was looking to just mount a tablet somewhere and still might depending upon of this mock-up looks.
I came across a full featured slim Android head unit that sparked my interest.
https://rover.ebay.com/rover/0/0/0?mpre=https://www.ebay.com/ulk/itm/232935740710
For the time being I would just use a line converter and plug that into the line in aux jack in the center console for sound.
Eventually I would run it to a 6 channel amp, upgrade the door speakers, add speakers to the rear pillars behind the 3rd row and add a powered sub. Would also add extra monitors in the rear and a front camera.
Rear camera would still show on the factory screen. Only issue I see is once I setup the amp I will loose the parking assist beeps.
In my head and putting my iPad mini up in the dash it does not seem too large but that is not with a pod housing.
So I am going to mock up a pod with craft foam and see if the pod would be too large and obtrusive.
Anyone know the part number for the removable tray there in the center of the dash?
Figure running wires down thru that and I’ll likely bugger it up a bit.
If I was crafty I’d figure out a way to have it fold flat into the tray area.
