Good things ARE coming our way from ICON Vehicle Dynamics, or so they say
Black
Black
Kentucky
Pipe dream going over 3” with any sort of suspension lift on these things unless you are just drowning in cash. For a full out custom fabrication of pretty much everything for the rear.
3/2 and a body lift sure.
I’d be tempted to say you possibly could sell the Expedition, buy a used raptor, and convert the bed to a passenger compartment for cheaper.
Grover6
Calgary
So Bilstein now shows ride height adjustable shocks for front and rear when I searched up my 2016 expy. 0-1" front and 0-1.5" rear. Had to check twice.
Black
Black
Kentucky
Sure does.
Still need a spacer for a 33” tire I’d say but running a spacer on a 5100 is likely a bad idea.
Grover6
Calgary
Probably, but I am only looking to go up to around a 32" so it will work for me. At least until Icon gets their act together. Just rolled over 65000 miles and feel the need to upgrade the suspension.
Aces
Murrieta, CA
I picked these up at icon’s parking lot sale. Take with a grain of salt but I was told the Expedition suspension options SHOULD be available by the end of this year. Please keep bugging them about this and show them that there is a market.
Black
Black
Kentucky
I presume those are F150 spec’d ICONs??
I was half tempted to run ICON or FOX fronts and Bilstein 4600 rears.
Was not sure how that different of a dynamic from the front to rear would be.
I presume you are having no issues??
Aces
Murrieta, CA
Yes they are f-150 spec’d. Yes I love them. They ride better then my old Halolifts (which will be for sale soon) and I’m not afraid to push them in the dirt. (Haven’t had a chance yet though other than dirt roads by my house)
You can tell the difference from front to rear but it’s not terrible. (Just makes me anxious to put icons on the rears.)
Black
Black
Kentucky
I presume they swapped in with no issues or modification?
Adieu
SoCal
Sure does.
You sure?
Stocks are 32", 33's are just 0.5" more in every direction... seems like 33 might fit stock just fine, and any amount of lift easily
Black
Black
Kentucky
You sure?
Nope. 33x11 likely would fit not so sure a 33x12.5 would. It is kind of close back there but I never measure at factory ride height.
The 18-19s with 1.5” or lift likely not an issue but only 1” or lift on the 15-17s likely close.
Adieu
SoCal
Width is width, that's different
Black
Black
Kentucky
True, but most folks tend to use and aftermarket wheel and wider tire as well so generally a good idea to tread lightly thinking something will work until it is verified.
My unexpected 4” lift from the F150 5100s is a great example. No way did I ever expect that much differentiation.
16plati
VA
You’ll need a 3/2 or equivalent to fit 33/12.50 on factory +44 offsets
joethefordguy
Depends on if you are an independent suspension or not.
Ride quality is degraded in both the matter of how much is dependent upon the setup.
Independent suspension helps to soften it out.
I’ll say that I now have rear spacers as they are the only option at the moment.
Paired with Bilstein 4600 I am very surprised and impressed on how well they ride compared to other vehicle I have ridden in with spacers.
would you recommend the 4600's for offroad use?
Black
Black
Kentucky
Off Roading is of course a relative term.
Not rock climbing or bouldering but I did some pretty solid trails with my 5100/4600 combo and my expectations were far exceeded.
Again I realize we are essentially off roading a school bus so sure we aren’t going to run serious trails and the like but these things do just fine for the kind of stuff I want to do.
Not my video but I did this in 2wd
And that track nowhere near maxed out the ability of these rigs when properly equipped.
Aces
Murrieta, CA
FFB48428-7277-4078-A8A7-AD47DC92997F.png Back from the dead but this is as much as I could get from icon.
Black
Black
Kentucky
Here is for hoping they have the lower levels too.
Top end is some super serious coin
Viv2017expe
San Rafael, ca
That is great news though. I think this will increase the value of third gen Expedition. Imagine turning these into raptor with room to spare especially the ELs...
LokiWolf
Moderator
Richmond VA
Never going to happen. The rear is the problem. Have you looked at the geometry of where the axles run? That is the issue!
