04EddyExpy
This is badass. I would love to put something like this on mine, although with slightly different wheels, most likely.
OH NICE! I've never seen mine with black wheels... and the black headlights... that's pretty badass too. Where'd you find the blacked out grille? What kind of lighting do you use?
I tried a full LED conversion on mine and I get hyperflash, even with the RockAuto "LED-friendly" flasher. If I add LEDs to the turn signal lamps, the flasher just buzzes and I get no flash at all. So I went back to Sylvania SuperBrights for the headlights. Still getting hyperflash so I'm gonna go back to Sylvanias on the fogs as well, to see if that gets rid of it.
Interesting. I’ll have to take it apart this weekend and have a look. It did work for a while after I put the LED friendly flasher in, so maybe it went bad at some point after.Fogs wont cause hyperflash unless you wired em in as turn signal repeaters
Taillight brake/blinker is your culprit. Or your replacement flasher relay is shot and causing hyperflash regardless.
Actually scratch that your flasher relay is DEFINITELY burned out or installed incorrectly
Yep, you were right. I installed a new LED flasher from RockAuto and the signals all work perfectly now. Still trashed the LED headlights, though. One actually burned out and I was just fed up with them. Incidentally, the old LED flasher was made in Taiwan... the new one was made in the USA and has been working fine for a week or so.Fogs wont cause hyperflash unless you wired em in as turn signal repeaters
