Guess this sound - Crackling Noise
Bwalker
Utah
I hear this crackling noise that seems to be coming from the drive belt area. It goes away, for the most part, when the engine warms up.
Belt Tensioner?
Here is a sample of the noise when cold:
https://youtu.be/ik9zZY43y3g
Here it is about 20 minutes later when warm:
https://youtu.be/kd2PIQA_isQ
It doesn't sound like the worn bearings I have heard in the past.
Any ideas?
Thanks.
2004XLT
CT
I would start by removing the belt and checking everything..alternators can make noises that don't sound like pulley bearings.
Bedrck47
Elizebethtown, PA
Question Guess this sound - Crackling Noise
Is there a reward if anyone guesses it correctly???
Start with what 2004XLT suggests
Don't run it very long with the belt removed.
docraymund
philippines
It sounds like you have worn valve lifters. Verify the noise by using a mechanic's stethoscope.
Temple, Georgia
Sounds like timing chains to my antique ears. As mentioned in an earlier reply check all the bearings that deal with the serp belt first.
How many miles are on the motor?
B
Bwalker
Utah
Thanks for the replies.
I was going to remove the belt on Saturday but it didn't make the noise. The temperature at the time was about 32 degrees. It must only do it when the ambient temperature is at or below about 25 degrees.
