Headlight bulb gasket
tk34
SE Michigan
When I went to replace the headlight bulbs (2014 XLT) one side had two gaskets - a black one sitting in the bulb recess and a red one on top of that - it was a very snug fit. The other side only had a red gasket in the bulb recess. I am assuming the bulbs are original since the truck has such low mileage. Can anyone tell me if there should be a double stacked gasket or just one?
Thanks
99WhiteC5Coupe
Thanks
On my 2015 Expedition Limited 4x4, purchased new and the headlamp bulbs changed by me - the low beam bulbs have a black circular gasket at the back of the bulb (on the lamp assembly).
The black gasket is a very tight fit and I have used silicone dielectric grease on the edges before replacing the gasket, following a bulb change.
The 2015 Limited has standard halogen bulbs (not LED or HID).
Cyclone
Maryland
Well, I changed bulbs in my Mercury Monterrey a few weeks ago. I was having a very hard time getting one of the bulb back into the housing. Turns out the gasket from the first bulb was still there. Two gaskets, too tight. Remove the extra and all was good.
So you may just have a left over gasket from a previous swap that someone man-handeled into getting it to work.
T
tk34
SE Michigan
Thanks, you're probably right, that double gasket may have been an attempt to fix a loose bulb...with one gasket it is not quite as snug as I'd like but 2 is way too tight. I might just try to slice that extra gasket in half and see what 1-1/2 feels like.
