shadow460
TL;dr What's the vacuum supposed to be on a healthy 4.6 engine. Are there any serious DTC codes the truck might throw?
The old truck threw me a P0401 yesterday which I traced back to either a faulty DFPE (sp) sensor or clogged ports. I replaced the sensor last year, which cleared that code for a good long while. Voltage changes from 1.1 to 1.25 while pulling a vacuum on the EGR valve, so I think the ports are clogged.
However, the troubleshooting process left me with a couple of questions:
First, what's the normal vacuum reading on a healthy engine? Mine sits at 18 and does not move until I hit the throttle. I think it went up when I hit the gas, but it slowly returned (took a few seconds) to 18 and set up shop there.
Second, are there any truly serious DTC codes? I carry a code scanner as part of my emergency equipment (jumper cables, jack, etc.). Anytime I get a code I read it ASAP. So far I've had (and successfully repaired) p0171, p0174, and p0403 (IIRC anyway... see above).
Gonna open up the engine a bit when three of four new gaskets arrive. I might change out the EGR valve itself for $60 just to get a lifetime warranty on that. While open I plan to clean the ports on the throttle body elbow and try to clean out or replace the hoses and the tube going to my exhaust.
