Mountain
Hi folks,
I'm stumped!
2005 Eddie Bauer Expedition, ~140K. Recently replaced the fuel pump control unit due to corrosion & a short. That got 'er up and running. At this time I repaired a leak in a brake line, bled lines & brake seems to be OK considering that now the engine won't crank. A check w/ an Actron scanner showed no link, indicating no power to the OBD. Here's the run-down in case anyone has an 'aha' for me:
-No link / no power to OBD2
-Relays click, but engine won't crank & no horn either. Replaced relays, no change.
-Checked all fuses. None bad & cigarette lighter works.
-All fuses had power when they should have had power.
-Pulled neg lead on battery for long time, no change.
-Tried locking / unlocking w/ key fob and keypad entry. Also pushed panic button then again to stop. Locks & unlocks ok, but I only hear the relays click when the horn should be honking.
-The dash warnings show 'Low tire pressure' (yes, I need to inflate one), 'Engine temp data error', and 'Charging system data error'.
-Battery is relatively new and fully charged, ~12.5 volts or more.
Any thoughts? Trying to fix for the family before I must go overseas for work. Thanks
I'm stumped!
