Bedrck47
P0155 is o2 sensor bank2 sensor 1 an p1409 os egr vaccum regulator solinoid circuit, is that what transmission thats in mine 4r100 ???
Possible causes for those codes can be an open circuit which you know you have
and yes to the 4r100 trans
When you make the repairs to the wiring and are 100% sure you have the correct wires re-connected MAKE SURE you place heat shrink tubing over soldered connections DO NOT use butt connectors or wire nuts That may be ok just to make sure you are correct but when doing the FINAL repair solder and heat shrink tubing
