Help with abs lines
justin931
Middle tn
Hey guys. So I’ve bought my first expy. It came with the abs control module already taken off as the previous owner said it was bad. So I’ve got the new part in and can’t find a diagram for where the lines go in. Can one of you maybe take some detailed pics for me if you have a 2010? I need to know the placement asap. The lines were bent out of place so it’s hard to tell where they went. I need to know where to hook up the front and rear into the module. Thanks in advance. Its 38* outside and I’m working on her now IMG_2703.jpeg
GlennSullivan
NY & FL
I have a 2011 which should be the same. These pictures may not help much as it is difficult to see where each line goes without putting it in the air. Looks like the 2 lines that transition to braided go up to the master cylinder. I might be able to confirm that in a little bit.
