HELP with cranking
99 Expy
Laramie, WY
Hello once again everybody. I have a problem that I need to fix as soon as possible. A couple of weeks ago, when I would start my expy for the first time each day, I would turn the key and it would just click. I then messed with the connections and eventually it would start. It would then start fine the rest of the day. After sitting for more than a few hours, it does the same thing. It has only been doing it when it has been really cold. When I was back in Iowa for the turkey day, it did it once. I then cleaned all of the ground and positive connections. I have thought of replacing the battery terminal connections, but haven't yet. After I cleaned them, it started right up everytime, but it was above 20 degrees. I got back to Laramie and tried starting it today and nothing. Are there any tests I can do? (I put a charger on 12 high for a few minutes and all cells boiled) Does this sound like connections or battery? If anyone has any ideas, I would appreciate them very much. The temperature for the next week here is -10 windchill, so I would like to get this done in as short of time as possible.
Thanks
Zerick
panda24619
San Diego
do you have an alarm? my gfs car has an alarm and no pod. so it clicks some times. she presses a button on the side of where the sensor is and no more problem. hasnt happened for at least a few months now.
Racenut
Deming, New Mexico
I would go to your local Autozone or Oreilly ( or any other parts house ) they usually have a hand held tester where they can test your battery and charging system in your car so that you don't have to pull anything. Being that cold it could be a battery getting weak.
If the battery passes, then I would look at changing out the terminals since there maybe some corrosion built up in the end of the cable itself.
