Help with low power
Only_in_a_yj
WV
Hello all. 2010 Navigator 5.4 3v with 186,000 miles. I recently noticed a significant decrease in power between about 1800 and 3000 rpms. The power picks up above that. It surged very bad when it started but is much smoother now after what's listed below, but still no power in that rpm range. I've list everything below that I've replaced or tested. Any help is greatly appreciated.
Replaced spark plugs
Replaced all COPs
New air filter
Cleaned MAF
Checked exhaust back pressure at first O2 sensor. About 1 psi at 3000 rpm
Cleaned throttle body
New thermostat. It was only reaching 185F before. Now 200F
Fuel pressure tested at 45-50psi when driving.
No obvious vacuum leaks.
O
Only_in_a_yj
WV
My scan tool shows the system switching from "CL" during normal driving to OL-DRIVE" if the pedal is pushed past about half throttle. I assume this is open and closed loop but shouldn't it stay in closed loop once warmed up?
Bobmc
Don't know if this F150 low power problem applies to your vehicle, but it might be worth a look inside/below the air filter. Some good talk on scan use also.
TobyU
Ohio
I like this guy for his knowledge and experience BUT I HATE youtube crapeos!
I'm glad I know it had an intake restriction but I would have like to not HAD A BIRTHDAY before he got to it!
And I'm NOT an impatient person.
He wasted all the scan time etc when he heard the air hiss from the beginning.
He is a smart guy and probably knew what to look for right of the bat but he JUST HAD to waste all the time and make it a more leaning exp!
I begrudge him the money and play time I just gave him!! ARRGH!!
Soon as you hear the hiss you open hood and look...soon as he saw the collapsed plastic and resonator box....knew it was blocked somewhere!
You know the KISS method....well how about a GTTP....Get To The Point method.
Did I mention I HATE repair videos?
I hate repair videos! I hate repair videos! I hate repair videos! I hate repair videos!
Seeing or even reading that is a lot less painful that watching most all repair vids.
max78
AZ
I had a similar surging issue, mine turned out to be the tensioner. It was bypassing enough fluid to effect my VVT.
I replaced my tensioners and installed a melling pump and its been smooth and powerful ever since!
TobyU
Ohio
Yours was probably able to rev past 4200 though.
Low revs are classic sign of restricted air in or air out or way too much oil.
07navi
Mt.Shasta California
O
Only_in_a_yj
WV
Mine will rev up to the limiter, it just has to downshift and get the rpms past 3.5k and pull from there.
I changed the engine oil and manually cleaned the fuel injectors yesterday and that didn't help my issue. But when I emptied my catch pan today I found alot of fine metal shavings and some bigger pieces. My plan is to pull the valve covers and inspect the followers and cams.
07navi
Ya most of the people that make them are novices and they make me cringe sometimes. Makuloco makes money doing that though and I see him making mistakes sometimes or doing things the hard way.
TobyU
Ohio
I usually find his videos a lot more interesting but that was just way too long-winded and was a real waste of time getting to the actual point.
07navi
He is a real mechanic which is rare anywhere on the net unless they want money so it's a win-win situation because he does get paid but he does drag things out a bit and pretends to torque everything and actually doesn't but that's OK I just laugh about it. When I was a mechanic working in different garages I rarely saw a torque wrench anywhere.
O
Only_in_a_yj
WV
I found one bad lash adjuster and both timing chain tensioners are blown out. I'll pull the front cover tomorrow and go from there.
07navi
Even the intro with that slow moving rusted steel door is too slow and I have to fast forward it. I told him and he said " I guess all the intros on your favorite movies are too long too".
browncow
