BigBlue22
I have a 1999 Expedition with 212xxx miles. It has been running great. Drove it for a short run to the store. Came out and try to start. Nothing. It is like something has sucked all the power out of the truck. It will not do anything. So I took the battery out of the truck and had it checked. It is fine. Jumped the relay on fire wall by running a wire from the +battery side to the small push terminal. The truck then turned over. While at the parts store I purchased a starter relay(on firewall by battery) and ignition switch. Installed the relay and put in the battery. Cranked the truck and it started. Was elated. So I turned the truck back off and once again nothing. The truck again is acting like it has had every ounce of power sucked out of it. I need some ideas and help. I am stuck in Augusta, Ga and have to be back in Atlanta, Ga by Sunday night.
