I have a 1999 EB Expedition with no heat in front or rear. Changed T-stat, both heater cores and still no improvment. Heater core hoses are lukewarm, rear heater core hose are stone cold. Upper rad. hose is hot, lower rad. hose is lukewarm. Coolant level is normal hot and cold. Engine does NOT overheat. No coolant dripping from water pump. No coolant leaks anywhere. Blowers work fine, blend doors and actuators good. Wondering if the t-stat could be the wrong temp? I installed a 195-degree one. Also, could this be related to a vacuum leak in the only vacuum actuator on the truck? I'm hearing a pssst sound coming from under the dash. I know the electrical actuators are good, I already tested them all. Any solutions, suggestions are greatly appreciated.
