I Keep Coming Back !
Discobee
Seattle, WA
I bought a 07 Eddie B EL....sold it for a conversion van (I like me a conversion van too)....sold the van and got another 07 Eddie B EL....sold the second one for another conversion van....sold that van and bought a 13 Limited in black/black! I keep returning to the trusty and familiar Expedition EL ! It's the best SUV ever!
Discobee
Discobee
Seattle, WA
Then I swapped out the wheels in the pic above (was kinda curbed) for a set of wheels/Pirelli tires that were takeoffs from a 2021 F150...but the rear wheel center caps could not be put back on because the center bolt stuck out by about 5/8"...should I add a spacer to it to make it fit, or are spacers not advised?
bloodhound
Merica
Nice looking truck. Grab a sawzall and trim a couple threads off the axel end so the caps can fit. There is plenty of material there (I've done this on 3 Expy's now, no issues).
And while you're at it, swap out the lug nuts for solid Gorilla nuts or the like.
Discobee
Discobee
Seattle, WA
Hmmm the sawzall route seems interesting...knowing me, I'll probably F it up but that is an option.
I didn't like the stock wheels at all...wasn't chrome, was kinda thrashed by the curb, and too many grooves to clean haha
Super stoked to be in an Expy again though....unless another super cool conversion van is located hehe.
JKH13
il
I sawed my rears on two of mine. Piece of cake. Just cut enough off so it's done in one
Luis Gomez
New Jersey
I run spacer on mine and never had an issue I know some frown upon them due to safety if the spacer comes loose. But I can tell I used them for years and swapped wheels in the winter and summer and have never found a loose lug. just make sure you torque them down and you should be fine
Motorcity muscle
Motorcity
Nice looking truck, like the original wheel too but would be a paine to keep clean. Are the rear axles all the same whether 2 or 4 wheel? Would like to get rid of my rims and use some 150 rims.
Discobee
Discobee
Seattle, WA
Thanks....my guess is that the 3rd Gen probably all the same? Maybe someone else more knowledgeable can chime in.
Discobee
Discobee
Seattle, WA
Sawzall with a good metal blade and let it rip? Did you have to do any sanding or filing on the bolt afterwards?
