Iacv problems
Tommy695
Alabama
Hey guys been awhile since I've been on here but I a few weeks ago my iacv started leakin air so I changed it and the new one was leakin to so I took it back and changed it out again and this one is still leakin are around the bottom of the gasket just like the last one. Is there something special you have to do to reinstall these things or a certain kind of gasket to use? It kinda seems like the new gaskets aren't big enough and that's why it's leakin. Any input would be appreciated.
Temple, Georgia
Make sure the gasket surface is clean by very easily going over it with a single edge razor blade or a zizz wheel. If it still doesn't seal, Permatex #2 is your friend.
T
Tommy695
Alabama
I've cleaned it both times I've changed it out and I just bought a felpro gasket to see if it was the type of gasket but it's still leakin so I'll try the blade and permatex tomorrow see what happens with that.
Temple, Georgia
Make sure you get the non hardening type of Permatex, I'm pretty sure it is #2. The #1 is hardening - pure evil if you don't have a ziz wheel.
Check the mounting for cracks. How are you determining it is leaking?
T
Tommy695
Alabama
Didnt get to do nothin ended up workin all weekend but I no it's leakin because its running like a turd at idle and you can here it leakin air and if you rub around it you can feel it leakin at the bottom of it.
