Ideas to make '14 Limited look a little different.
Yoop33
Yoop33
St. Orlampawater Islands, Florida
I have an Expy 13, Ive changed all lighting to LED. Upgraded the original 20 tires to 22s and ordered/installed the Platinum level rims.
How do you like the ride on the 22"s? I used to have a aftermarket set that I loved, but the ride was a lot rougher compared to 20"s.
And if you dont mind me asking, where and how much did you get those Platinum wheels from/ for?
gixer2000
Retrofit or Bust
Massachusetts
buzzie0013
California
Gixer2000
whats the rear chrome piece #, and how did you remove the old rear badges? i was under the impression that there would be holes to fill
ExpeditionAndy
Fort Wayne, Indiana
Gixer2000
The badges are held on by automotive double-sided tape. a heat gun should take them off.
This is what Gixer said earlier about putting on the trim piece.
It attaches just like the stock trim except you need to drill 6 holes in the liftgate for the extra push pin fasteners. I also needed to remove the stock badges that were in line with the moulding. The wiring required a little more work. The plate light sockets are not the same so you need the wiring harness. Took like 2 hours to get the whole thing done but worth it. The glass release is now under the N and my aftermarket camera fit right into the factory socket on thr moulding
Sent from my LG-G6 using Tapatalk
gixer2000
Retrofit or Bust
Massachusetts
Gixer2000
No holes behind the badges but I don't know the part number. If you look at my last post I left a link for one thats for sale.
Flexpedition
midwest
FYI, only the oval Ford badge has alignment holes. Not that you'd want to take it off or anything.
There are various part numbers for the liftgate trim, depending on regular length or EL, chrome or the satin dark grey, nearly black finish, etc. FL14- F43404-A, for example, is the EL chrome trim. It has "EL" molded/raised on the passenger side.
I've had 20s, 21s, and 22s on my truck and honestly the ride difference is negligible. Tire quality is an important factor.
lstrejcek
Florida
Anybody have the OEM part number for the rear lift gate chrome nameplate bezel that gixer installed? The part number Flexpedition listed above is for the EL; I have a regular length
ExpeditionAndy
Fort Wayne, Indiana
You are probably going to have to call your Ford dealer to get the part number. From what I understand they are about $400 new. You might find one in a junk yard. My service told me that before they warranty that part, Ford make the take pictures of it from all angles to make sure that nobody tried to pry it off. So they must be pretty pricey if they are doing that.
tifanydire
