im gonna kill my truck......
Big Red Monster
friday night it started shaking sputtering and misfiring, saturday i took it by the mechanic he told me to bring it back monday morning (just got back from the shop) well Im so pissed right now cause this morning it didn't shake didn't misfire or anything.....I told my mechanic just change the fu*king plugs if it doesn't do anything today. it wont throw a damn code or anything its so frustrating to figure out whats wrong or which col pack is bad. and yes i already checked that little elbow that develops the crack and vacuum leak the hose is fine
omegalita
Switzerland, SG
I have the same problem with mine...
Took out the sparks and coils, seems everthing fine, no spark was wet! And there was no code... Pictures here
Don't know where else to search...
By the way: which "elbow" do you mean? How cann affect a vakum leak this situation?
Big Red Monster
Big Red Monster
behind the intake plenum, check the thread labeled "rough idle" its all about that little elbow, it has a strong vacuum and if it gets a hole in it it really messes up the way the truck runs, but for me that wasn't the problem....that would have been to simple. maybe your coils are bad not the plugs, im expecting to replace atleast 2 coils, there hard to test
omegalita
Switzerland, SG
I checked that by unplugging each coil. By each unplugged Coil, the idle has gone down... Therefore, I think, my coils are good.
But i know, there can be a missfunction too...
I am in thoughts for you and hop that we can get a solution and our trucks running again!
Just a half men without my Gator....:bawl:
Big Red Monster
Big Red Monster
yea i hope to have my truck back to normal by wensday, i need my truck, thats my only way of getting around so right now it sucks having to ask for a ride to work and whatever else.
Big Red Monster
Big Red Monster
and out of my friends im the only one with a good vehicle to ride around in, so right now all of us are fu*ked.
toms89
technical advisor
MD
That definately sounds ignition related. If you go through all plugs and coil packs you may find evidence of misfiring plug. The higher the load the more likely to get misfire so it will not always be evident at low loads or idle.
If mass air sensor is acting up it could also give similar symptoms.
Big Red Monster
Big Red Monster
tom thanks for the info but theres is just one thing about that theory, sitting at idle friday night, it was shaking like my cousins grand prix with a 400 lift cam. it better not be the mass air flow sensor yet, that muthas getting replaced with one from jet in the summer. i really hope its the plugs so i can have my truck back by wensday at the latest. to my knowledge this is the first tune up its ever had
toms89
technical advisor
MD
That was more for the benefit of omegalita that checking coils at idle may not identify it. Misfire is more likely at higher loads but this is not to say it will not misfire at idle. I would look for signs of carbon tracking or moisture on spark plug, spark plug boot and coil. Many times a misfiring plug will look far worse than the others at the business end also.
By the way ... a .400 lift cam is nothing if you are speaking of valve lift. Most stock cams are more than that. But really its the duration and lobe seperation or lack thereof that create the lope . :p
omegalita
Switzerland, SG
I have misfire beginning at normal 850 or so...
Pics of the sparks you will see here!
For now, i change all the sparks and the coils. Next step, if still nod ok, i will check the ignition valves or clean them with ultrasonic...
toms89
technical advisor
MD
Water in the plug holes is not good. The spark will take the path of least resistance which many times is across the boot or whatever when wet. Not to mention the corrosion it causes.
If you replaced all your plugs and coils (including boot??) you should be good there. But in your photos it looks as if at least one connector is badly corroded. Did you replace this?? Also what is the plug gap...looks rather large but can't tell for sure with the angle of the photos?
Big Red Monster
Big Red Monster
Tom about the 400 lift cam ithink that is what it was, all I knows is it lopes like hell and the whole car shakes lol. Man I miss my truck I cant wait to get it back
toms89
technical advisor
MD
Fixed it :)
Big Red Monster
Big Red Monster
:893Chainsaw-Smilie-Hey that looks real good thanks tom lol. Really mad right now though, I found out they didnt even work on my truck today, and its been left outside on the street:893Chainsaw-Smilie-
alaskanexpy
anchorage alaska
same issue with my excursion...random misfires. i just replaced all the coils prob solved. i've had more issues with these coil over plugs then any other coil pack in my life.
omegalita
Switzerland, SG
Sorry...forgot to say, that the brown "corrosion" is just copper grease, from the dealer and that was the first foto. No water in there...
The gap ist about 1.35mm, in the manual it should be between 1.32mm and 1.42mm. The sparks just ran 10'000km (sorry, i'm metric.. :) )
For now, the car is in the garage and is waiting for the material...
So...it's 7:41 AM and i should get to work.. Have a nice day!
Big Red Monster
Big Red Monster
update. Im no longer going to kill my truck. Im gonna kill my mechanic instead. my truck sat all day yesterday and as of 11:38 am today, STILL NOT F*CKING WORKED ON!!!!!!
Big Red Monster
Big Red Monster
update, found out all 8 spark plugs are shot to hell and i need one new coil, should be getting it back later today, really cant wait to see how it runs.
Big Red Monster
Big Red Monster
got it back today. it runs so smooth now and my mileage has gone up to nearly 12.5 mpg now, Im happy lol
