TheFordFortress
Does not have BCM in Forscan, but looking for info on the following changes if anyone has it...
1) Auto Window Closure with door lock from fob
2) Bambi Mode options
3) Stealth Lighting Mode
4) Smart Seat upon Entry Exit from car
5) Making Stereo and Accessories stay on longer after Key Off
6) Engine Hour Meter
7) A Stay on Mode for the engine after key is removed but engine shuts down when brake pedal is pushed to put into gear.
Is there a way to get all doors and tailgate to unlock when you exit the car from the drivers side without having to press the unlock button on the door or fob? Nothing worse than getting out the truck to open the tailgate and finding it locked and having to go back and press the door u lock or fob in the ignition.
Also without BCM where would I find out if there is possibility of Remote start option.
I know it’s a list and I have dabbled in Forscan trying some of the options in the 2015 spreadsheet but many of the modules listed or lines of code are not present in the 2009.
Thanks in advance for any and all assistance!
Mike
Mike
