Interior Led swap.
Robert Castro
Tx
2007 Eddie bauer got a led interior swap over the weekend. Took about 20 mins to do all of them but encountered 2 issues that may be an easy fix. The lights come on when you open the door or turn on all interior lights at once, however, when you click on an individual light to turn it on it will not. It does click but doesnt activate the single light to come on.
2nd issue, the glove box light does not come on at all. Possible fuse issue?
Any suggestions?
Sent from my SM-G955U using Tapatalk
LokiWolf
Moderator
Richmond VA
Any suggestions?
LED’s are typically directional, as in + has to be + and so forth. Flip the bulb around in the glove box, and see if it works. No idea on the other issue.
TXFRDOwner
Wiggle them around, sometimes they don’t make contact
R
Robert Castro
Tx
I did do that. It may be in wrong. There is a small plastic wall that makes it hard to see.
TXFRDOwner
Yup I have the same truck 07 EB.
I ended up spreading the leads on the led bulb to ensure a snug fit and no intermittent contact
MuddySpokes
There & Here
I am having a tough time connecting the responses to the original statement about all the lights turning on when opening a door, but not when trying to individually turn them on.
For the folks giving guidance on fixing polarity and / or metal-to-metal contact, can y'all offer a little more insight with how that might help when the lights apparently do work as they are now? Is the socket dual polarity? Or . . .?
LokiWolf
Moderator
Richmond VA
He had 2 problems. One was the glove box light not working at all. I addressed that.
fuzzmanmatt
They may be dual-polarity. I don't remember on mine, I know that the LEDs I used had four contacts on the 194 style bulbs, but the festoon bulbs didn't. I'll run out and take a look on my lunch. I know I had issues with the rear cargo light when I added the SoundOff dome lamp, I had to tie into the bulb contacts instead of the harness to get it to work like I wanted.
fuzzmanmatt
Okay, so there are three wires, one is ground, one is hot all the time, and one is hot from the GEM when it says to be hot, so there shouldn't be a polarity issue. There may be a connection issue or a fuse someplace that's not working. I'd grab a test light and probe the connector to make sure the wires that should be hot are.
Sent from my moto x4 using Tapatalk
fuzzmanmatt
For some reason I couldn't upload from my phone, so here's what I've got for pictures:
Josh Raley
Desert
Has anyone figured this out? I just replaced the all the lights with L.E.D on my 2013 exp and now they are doing the same thing as the o.p
cdahlen
Milan, Illinois
Check the fuses using the guide. Can't remember if it was my expo or the escape I had before it got totaled, but lights have 2 separate fuses.
Josh Raley
Desert
Thats what it was noticed that my visors lights and garage door opener wasn't working looked for a fuse and must have blown it pulling them out.
Thanks!
