Keyless entry
Stuart Adkin
Surrey B.C. Canada
with out going to a dealer I am trying to find the keyless code for my 03 Expedition. I know their should be stickers with the code inside in two or 3 different locations.
Hampton, VA
look in the glove box and see if they wrote it in permanent marker...and theres a box with it on it somewhere deep in the engine...dont know where but there are a few threads stating where
sgtowing
Supporting Members
Valrico, Fl
Look up behind the passenger kick panel and there is a box with 5 bold numbers. That is the keyless code.
Sent from my Galaxy SIII Using Tapatalk2
Hamfisted
Ft Lauderdale
Yeah, the code is on a sticker on the security module just forward of the fusebox at the passenger side kick panel. Pull the cover off the kick panel and look up there with a flash light. It's pretty obvious when you see it.
-Mike
S
Stuart Adkin
Surrey B.C. Canada
Hello I want to thank Freeway, sgtowing and Hamfisted for their response to my question. I found the code, I tried it but nothing the all doors were unlocked and I hit 78 90 still nothing . In the owners manual I located all fuses for locks fuses are ok. now I have my work cut out for me. I will pull the door panel check the plug connection for contact. any suggestions, once again thanks take care have a great day
Hamfisted
Ft Lauderdale
Do the locks work when you hit the switches in the truck ? With the FOB ? But not when you enter the 5 digit code on the driver's door keypad? Or do the electric locks not work at all, with any switch?
-Mike
ELVATO
Orlando, FL
Do the buttons light up when you press them? All the buttons should light up when you press any of the buttons.
FordGate
Damascus, MD
Also pressing the last 2 at the same time should lock all the doors regardless of what the code is.
johnjohn205
