Keypad Entry Help
G
Guest
I recently purchased a 2000 Expedition and haven't been able to use the keypad entry. I found the code but when I enter it nothing happens. My question is if you press anything on the keypad will it light up? Mine doesn't so I wasn't sure if that is the problem. If it is supposed to light up is there a fuse for the keypad? Any help is appreciated.
Postaltx
Fred69
There is a procedure for the keypad in the owners manual it is just short of tedius.. Yes the keypad should light up when any # is pressed. maybe the bulb inside has gone out, also in the manual is the fuse assignment. I cannot recall off hand which one it is.. the code on the card should allow access as a default code then you can jump thru hoops, and fire and program your own...
Keydo
SoCAL
Postaltx
I don't know if it would be compatible, but I have the keypad with harness from my 2003 EXPY when I replaced the window still.
I suspect Ford kept the connecting harness the same and I compared the keypad to our 98 Navigator and visually looks the same.
Drop me a PM if you are interested in the keypad.
PaulC
NE PA
Postaltx:
With the door key in your pocket, Press the [7|8] and [9|0] buttons at the same time. If the keypad is working, all the doors and tailgate should lock. If they don't, the pad isn't receiving power.
